What motor oil are you using?
Hi Guys
what oil or what oil weight (specs) is recomended on a street/drag motor built for nitrous whith ring gap .026 top ring .028" 2nd
its LS2 404ci 11.4 in CP
What are you using
thanks
Baezi
What are you using
thanks
Baezi
I have big ring gaps on my 416 l92.Top ring gap is .026 or .028 can't remember. I have run rotella 15-40 but i like the 20-50 vr1 oil I am using now. But I also have extra oil clearence on rods and main bearings.
Castrol 10w 40 change it every other time to the track or if I run it real hard I change it before the next time I go. I also use a wix filter which I would Highly recommend, Did this on my old 370 ran it for 2 years and my engine builder said the motor looked new on the inside with very little wear.
