new pads and roors and now I have a brake rubbing noise after I make right turns
Old 07-17-2011, 11:10 PM
crazyelf's Avatar
Default new pads and roors and now I have a brake rubbing noise after I make right turns
so I just did a full brake job, Ive done his before and im fairly certain I didnt install anything wrong.
Basically when I turn right I sometimes get a rubbing noise from the passenger side rear brake and when I apply the brakes it seems to go away. But I can still slightly hear it for a few miles after while going straight. Ive already taken the wheel off and checked it out for any weird rubbbing and didnt see anything.
It doesnt happen everytime I turn right, mostly if its a harder turn.
Any ideas guys???
Old 07-18-2011, 03:43 AM
SVThuh's Avatar
Excessive axle play in the rear?
If you pull the caliper and rotor off and violently push and pull the axle in and out, how much does it move?
Old 07-18-2011, 08:17 AM
Save the manuals!
wssix99's Avatar
Did you adjust the parking brake to your new rear rotors when you did the job?
Quick Reply: new pads and roors and now I have a brake rubbing noise after I make right turns
