Wheel Hub Bearings...again....
Does anyone know the size of the axle nut for a 2007 Impala SS
I need to purchase a socket to get to my hub bearings...
These things go once a year, so I figured I would try it myself this time
http://www.paulstravelpictures.com/G...ent/index.html
Procedure states 36mm..sounds about right?
Can anyone verify 100 ft-lbs
Thank you
Scott
Thank you
Scott
100ft lbs is wheel lug nut torque i think wheel bearing are around 180 thats what alot are but i could only find spec on that vehicle showing 118ftLB so im not sure either?
