Fuel Poring Out of Exhaust port
Old 07-18-2011, 03:27 PM
moehorsepower's Avatar
Default Fuel Poring Out of Exhaust port
I just want to let you all know in case this happens to you because I have never heard or seen this. The shop was trying to start my car (new engine rebuilt with a turbo) and they said that fuel was "Pouring" out of #5 exhaust port, I thought, Pouring? No way even with the 95Lb injectors. I get there and the #5 spark plug was removed and when the mech keyed on and off, yup, Fuel was literally pouring out of the exhaust like a gas can, we unplugged all of the injectors and still the same. I thought the fuel pressure regulator? about that time Mike said to remove the vacum line that goes to the regulator. When he keyed on, fuel shot out of the vacum line. As you all know the vacum line is directly across from the #5 port, so it was spraying fuel across inside the intake into the #5 cylinder..Crazy!
Old 07-18-2011, 05:27 PM
flyinZ's Avatar
Nope, never heard of that either. Not sure what to say, to try an help you Moe.
Old 07-19-2011, 04:16 AM
boostedlt1's Avatar
happened on my car, exept i had it coming out of about 3 cylinders. took me forever to figure it out, sometimes you over-look the obvious.... :/
also happened on my buddies car, expect as soon as he told me what was happening i told him to pull the vacuum line off and bam, problem solved.
also happened to someone in my local club. lol
Old 07-19-2011, 06:22 AM
Village Troll
SS RRR's Avatar
Good thing that was caught before any cylinder pressure could be applied or you would've most likely had a brand new, hydrolocked engine. What kind of fuel pressure are you running?
Old 07-19-2011, 07:45 AM
Yea I'm glad the engine didn't start, I am running dual in tank Walbro GS 340's with stock pressure, but at that time the pressure was around 53lb..
Old 07-19-2011, 04:44 PM
05HD's Avatar
Reminds me of when I worked for Cadillac roadside service. Got to the guys hose and the whole garage reeked of gas. I looked and there were big puddles by both tailpipes. Dragged it back to the shop and pulled the intake, it was completely full of gas, along with the crankcase. Nearly 10 gallons worth in all.
Make sure the oil and filter gets changed before the engine is turned over again.
Old 07-19-2011, 05:12 PM
Bad thing is before we found this problem they had already changed the oil for the second time and the plugs, now it will be on the third time with 0 time on the motor. But plugs and oil are a helluva lot cheaper that a new motor...
Old 07-20-2011, 10:40 AM
4SFEDZ's Avatar
my aeromotive regulator did the same thing. although i found it after the car sat for awhile and changed the oil. they fixed it for free tho!
Old 07-20-2011, 11:26 AM
Village Troll
SS RRR's Avatar
It's been argued the stock regulator is the best one you'll ever buy or need.
Old 07-20-2011, 12:33 PM
quik95lt1's Avatar
thats why i didn't run a vac ref line on mine
Old 07-20-2011, 12:37 PM
I guess mine varnished up or the diaphram dried out from sitting for almost 3 years, the regulator itself is around 11 -12 years old. I don't think Aeromotive will take it back.
Old 07-20-2011, 02:27 PM
TwoFast4Lv's Avatar
Been there done that. You are lucky it did not Hydralic the engine.
Old 07-20-2011, 02:38 PM
Tony Shepherd's Avatar
Thats just crazy!
I wonder if you could put a one way check valve in the vaccum line?
Old 07-20-2011, 02:39 PM
93QWKZEE's Avatar
Wow scary that this can happen with aeromotive's.I have one and will keep an eye on it for sure! good luck with getting it all dialed in...
Old 07-20-2011, 02:43 PM
There is a one way check valve for the opti so you don't pressurize it under boost, The problem is on a boost reference regulator, that is what it goes by, pressure being fed back into the regulator. So if you install a check valve, the
regulator will not operate as designed..
Old 07-20-2011, 02:46 PM
I know the first time they did start the engine and it supposedly ran for a few seconds and died, we thought it was the driver box so I purchased a Versa Fueler, same thing. So I am also hoping they did not hydrolock the motor. The shop told me the last time they tried to start it is just locked up, no crank because I guess the cylinder was full of fuel..
Old 07-20-2011, 02:59 PM
License2Ill's Avatar
Can this lead to kabooom?
Was thinking about replacing the stock regulator with something aftermarket but this is crazy.
Anyone know of a good 1?
Anyone remember the link to the site that showed you how to rebuild the stocker and also make it adjustable?
Old 07-20-2011, 04:12 PM
Yea I thought of that after I posted. Was about to go correct it. lol
Old 07-20-2011, 05:30 PM
Yea, I was thinking the same thing then but then I though, Doh, well that wont worklol
Old 07-21-2011, 02:02 PM
Formula383's Avatar
I couldn't believe it when Tony told me what happened. I'm glad you and Mike finally found the issue.
Quick Reply: Fuel Poring Out of Exhaust port
