SLP Lid-MAF
Old 07-18-2011, 07:57 PM
drummer_192's Avatar
Default SLP Lid-MAF
Im looking for the coupler that mounts the MAF to the SLP Lid. I pulled the procharger off the car when I bought it and it didnt have the stock Ram air intake set up, so I ghettod something to get me by, now im looking to get it set up back to stock. Ive got the ram air box, and the SLP lid, now im just looking for the coupler. I got both the box and lid used so I didnt get the correct coupler.
I pulled the picture of GM parts direct, i believe its number 3 that Im looking for but if anyone else knows if that will work, or something better to make them work thatd be great.
Old 07-19-2011, 10:28 AM
Anyone?
Old 07-19-2011, 12:06 PM
gpr
gpr's Avatar
I'm in the same boat as you. I believe #3 in that picture is what goes from the stock air lid, to the intermediate air box (the big bubble thing #9). Then from that #9 to the maf i think there is suppose to be some sort of rubber deal to attach #9 and the maf... Or at least that is what i'm assuming. my car didn't have anything and the maf was simply stuck inside the SLP air lid opening when i got it, this isn't correct is it?
Old 07-19-2011, 12:46 PM
Yeah on second look, I think youre right.
I wouldnt imagine that being right, at least without something around the MAF. I was thinking of getting some 3" rubber hose to put over the MAF and put into the lid. If it has an airtight seal I dont see why it wouldnt work? But if someone else has a better idea....
Old 08-03-2011, 08:47 PM
Still looking for a fix to this. Anyone?
Old 08-03-2011, 08:58 PM
Moderator
jimmyblue's Avatar
Did you look at the Baker Precision lineup of turbo hoses? They
have about every in/out ID combo you could want, a bit shiny
for my liking but there's always paint.
Old 08-03-2011, 09:09 PM
Ill check them out. Im not looking for anything fancy, just something to make it work. Ive seen pictures of other TA's where the MAF slides right into the lid. But mines got a decent sized gap around the MAF when its in the lid...whatya get for buyin used I guess.
Old 08-04-2011, 01:39 PM
Moderator
jimmyblue's Avatar
If it's just a little slop, wrap a few turns of black electrical tape
ans slip it in, then clamp for tightness? Maybe a few more slits in
the seating area of the neck will let you clamp it in better too.
Old 08-04-2011, 03:21 PM
drone's Avatar
the maf just goes right in the slp lid. then you use an slp smooth bellow like this to go from the maf to the throttle body. simple. http://www.speedinc.com/cont.cfm?cid=C0000008
Old 08-04-2011, 03:31 PM
drone's Avatar
slp lid. the maf should be tight in the lid even without the clamp.
Old 08-04-2011, 03:35 PM
babbage1109's Avatar
Yeah^ my Maf goes directly into the lid you just have to use some elbow grease and maybe a hair dryer to heat it up
Old 08-04-2011, 03:44 PM
SnakeEaterTA's Avatar
Yup no need for that cuppler, MAF should fit tight inside the the SLP outlet. Just take your time working it in.
Old 08-04-2011, 07:25 PM
My lid must be bigger. my MAF slides in with no elbow grease whatsoever, its probably a quater inch gap on each side of the lid.
Old 08-04-2011, 08:22 PM
I take back my statement. I just tried pulling my maf out and it wouldn't budge. If you dont care how it necessarily looks. Just go to home depot or something and get the pipe connectors. Measure your inlets n all that first. Or idk try turbo piping couplers. Silicone couplers dot com
Old 08-04-2011, 08:30 PM
Yeah i think thats the best option at this point. The stock is 76mm which is approximately 3 inches right?
Old 08-04-2011, 08:32 PM
Right!
Old 08-04-2011, 08:41 PM
Awesome. Thanks man.
Quick Reply: SLP Lid-MAF
