Paint & Body Work - Removing sharpie?
coeushog
07-18-2011, 09:01 PM
Earlier today I discovered some nice citizen wrote on the back of my new truck with a sharpie. Does anyone know a way to remove it? The truck is pearl blue metallic. Thanks
SinisterZ28
07-18-2011, 10:07 PM
You can try some thinner on a rag n gently rub off,then take a small amount of compound, you can try just some compound first,cause you need to be easy with the thinner cause it can soften paint, usually not on factory paint but more so if it's been painted so be easy with it
johnp94
07-19-2011, 05:47 AM
Try soap and water. I used to use sharpie marker to color in a scratch on my car. After four or five washes it would come off. Then I had to reaply.
ZexGX
07-19-2011, 12:36 PM
Try a dry-erase marker over it (test a small portion first), or a pencil eraser.
bgon99ss
07-19-2011, 01:13 PM
clay bar should take it off
trans_am7935
07-19-2011, 05:28 PM
this is the best way. we do this to take permanent marker off white boards
fucter
07-19-2011, 05:32 PM
rubbing alcohol
ZexGX
07-19-2011, 05:34 PM
Agreed. I use those two methods on pretty much any surface that has permanent marker that needs to be removed fully or at least mostly.
Xsta Z 28
07-19-2011, 09:09 PM
Yup . . . may not get it all, but it is amazing on how well it works!
Fosnot
07-21-2011, 03:06 AM
rubbing alcohol
This.
ramairetransam
07-21-2011, 06:42 AM
mr clean magic eraser
ZexGX
07-21-2011, 11:22 AM
Fuck no. That shit's essentially sandpaper.
Jeremy@RPMTransmissions
07-21-2011, 12:38 PM
rubbing alcohol
This.
x3 :cheers:
pillarpod
07-21-2011, 07:28 PM
rubbing alcohol
bing go :judge:
Conrad
07-21-2011, 07:35 PM
Definitely don't use thinner...I'd try a claybar first cause it would be completely safe. If that doesn't work try rubbing alcohol like others said. Friggin kids, who writes on someone's car with a sharpie?
Black_Z28
07-22-2011, 12:16 AM
Umm, insurance company might do a pretty good job at removing it.
StealthWeaponLS1
07-22-2011, 01:51 PM
What about those eraser wheels that you can use to take off glue left behind from factory emblems? Would that works or would it just do more harm then good?
SuperSport01
07-22-2011, 04:32 PM
Wash with dawn soap on the affected spot. Clay bar with quick detailer as lube. Hand polish and then wax. Its what I would do.
dontbl1nk
07-22-2011, 05:15 PM
Rubbing alcohol is hot enough to get rid of Sharpie but wont ruin your clear.
DukesOfHazard
07-26-2011, 06:53 PM
Those are moreso for removing pin stripe and adhesives. You run a chance of burning the panel if you try to remove the sharpie with that (at least on a plastic panel).
Acetone is the first thing I'd use followed up with a finishing compound to remove any haze/smearing if it's a dark color. Lighter colors you don't have to worry about it.
