Airbag module
Airbag module
so i just replaced my airbag module with one i got off here (guy said was good, never deployed airbags). i swapped my gauge cluster recently and the tunner said my airbag module was bad so i swapped it out and the light is still on. does anyone know how i can reset the airbag system to stock so the light turns off? i have also heard that after a cluster swap the airbag light will stay on untill a re-sync is done. so i am a little stuck, and just want the light to go off so the bags will deploy in an accident. any advice is welcome
Any dealer can clear the code for you. I'm assuming it was showing an internal failure code if your tuner said it was a module. I would say bring it on by our shop and we could take care of it for you but your a little ways away from Arkansas. -Nick
