how often do you guys change your clutch fluid?
Old 07-18-2011, 10:26 PM
Floorman279's Avatar
Default how often do you guys change your clutch fluid?
also, what brake fluid do you guys use? thanks
Old 07-18-2011, 11:58 PM
ProTreeRacing's Avatar
Every oil change at least. If racing heavily more often.
Old 07-19-2011, 01:42 AM
WheelsUp84z's Avatar
I check pretty regularly. I would say twice a month. I use the ranger method with the syringe. If it's discolored or dirty I'll flush it out. I race every week so I usually end up changing it every other. I use DOT 5.1 synthetic. I buy mine from a motorcycle dealership. I forget the brand but it's pretty expensive at $16 per pint.
Old 07-19-2011, 10:28 AM
SNLPerformance's Avatar
You have to be careful using synthetic fluids in these hydraulic systems. We use DOT 4 Non Synthetic here at the shop, works well for us.
I recommend at least twice a month. On my personal car I pop the hood when I fill up and look at the fluid... I beat the living crap out of my daily though, got to keep my clutches in line.
Old 07-19-2011, 01:18 PM
strokerrace's Avatar
SNL,
Why not synthetic? Just curious as to the problems/issues it causes.
Old 07-19-2011, 01:44 PM
Originally Posted by strokerrace
SNL,
The seals in the slaves, no matter the brand, are not intended to be used with synthetic. They will deteriorate over time.
Old 07-19-2011, 07:04 PM
you guys really change it that often? i just checked mine and it was a golden brownish color.....how bad is that? its been a good 15000 on that fluid. The fluid was a foggy color when it was first put in....the tranny is definitaly the part of the drivetrain that has it the easiest.....i really dont push the clutch in/out that quick at all, and dont rreally shift hard. i wonder how often gm suggests in the warranty part of our manuals? anyway will basically any dot3/4 get the job done
Old 07-19-2011, 07:13 PM
Ehatcher's Avatar
I havent changed min in the almost 7 years I have owned the car... drives fine.
Old 07-23-2011, 10:22 AM
ECU_Pirate's Avatar
I use Valvoline DOT 3/4 fluid and change mine out every 2-3K miles or if its dirty.
Old 07-23-2011, 10:36 AM
Really depends on how much you launch, power shift the car as to how quickly it gets dirty. The hydraulic system on the t56 is already handicapped enough and I just like to ensure that everything is working to the best of it's ability. You can run any 3/4, but the higher the boiling point the better. Prestone Dot 4 is the highest non synthetic that I know of and is what I run.
Old 07-23-2011, 10:51 AM
ECU_Pirate's Avatar
I'll be looking for this stuff next, where do you get it from? The pedal feel in my car compared to what I remember it was in my old '97 Z28 M6 is much softer and gets softer over time. I dunno if different fluid will help but with uncoated LT's I imagine the fluid handles a lot of heat.
Old 07-23-2011, 11:46 AM
Grifter's Avatar
Unless you're heavily racing your car I see no reason to change it that often. Every oil change? Twice a month? Come on guys.....
I have had mine in for about a year and a half and have about 15-20 passes and it's still clean and everything is working properly. Changing it reguarly won't hurt anything but it seems a little excessive. I have worked on cars that are 5-8 years old and the fluid is still good, I usually recommend a flush(a lot of people never consider clutch fluid when thinking of maintanence) but for the most part it's alright. And this is coming from someone who has access to a pressure bleeder that once it's set up takes, no lie, about 7 seconds to bleed the system.
I use DOT 4.
Quick Reply: how often do you guys change your clutch fluid?
