Rear frame? Im new, and dont know much.
Old 07-19-2011, 12:42 PM
kevintkrebs's Avatar
Default Rear frame? Im new, and dont know much.
my rear frame is bent downward from an accident, is there a better way to fix it than, soldering a new one on, like bending it back somehow? Just trying to increase my knowledge.
Old 07-19-2011, 01:05 PM
2000PewterT/A's Avatar
Well first of all I would take it to a collision repair facility and have them look at it. Second of all you can not solder that sort of thing back on. The only thing soldering should be used for is wiring. I am assuming you meant welding when you said soldering.
Old 07-19-2011, 02:20 PM
crazyc1123's Avatar
First off F-bodies don't have a frame. They are Uni-bodies (the definition being that all the components of the drivetrain) If the rear end is bent downward then there is some serious work to be done. Might be able to pull it out with a frame machine and a very experienced bosy tech. Otherwise youre lookin at welding a lot of replacement panels on.
Old 07-19-2011, 02:30 PM
Yes welding of course, im stupid forgive me, is this basically a lost cause?
Old 07-19-2011, 02:49 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Only a qualified body shop repair facility is trained and/or equipped to answer that question.
But this guy decided not to go and just lived with it....
Old 07-19-2011, 03:32 PM
kingd_202's Avatar
^^ lol
Old 07-19-2011, 03:38 PM
blk/slvr02ss's Avatar
U Can replace rear frame rails but it is a big job and your best bet is a Frame Machine to put it back to factory specs !!!!!!!!!!
