baer claw gt rotor question
Old 07-19-2011, 05:18 PM
4door5g's Avatar
Default baer claw gt rotor question
i got a set of the baer claw gt 13.1 rotors on my 02 ws6. but there warped and need replacing. they want $450.00 for a set of rotors.(keep in mind there 2 piece so its like half a rotor lol) my question is can i run some corvette rotors on it? i think there 13.1 also. if not, what could i run? i just forked out a ton of money on doing the tranny, and really dont want to spend almost 500 on rotors.
Old 07-19-2011, 05:24 PM
trans_am7935's Avatar
i believe the vette rotors that will fit on our cars are 12.8"
Old 07-19-2011, 07:13 PM
4door5g's Avatar
i read some where that the zr1 rotors are 13.1" was wondering if i can use them. i just fill like 450 is to much. i mean theres tons of life left there just warped
Old 07-19-2011, 08:27 PM
joe77's Avatar
Have you tried to get them turned?
Old 07-19-2011, 10:41 PM
4door5g's Avatar
im planing on taking them to my buddys shop next week to try and see if it will do it. but i always heard you coudnt surface drilled and slotted roters.
Old 07-20-2011, 01:50 PM
whoever told you that drilled/slotted rotors is a freaking moron! i have slotted and drilled rotors on my jeep for the last 8 years, and i have turned them once already. as long as they are in spec, then you can turn them just fine. just make sure to clean out the vented part (as shavings tend to build up there) as some shops forget that with the holes in the rotors the shavings go into the vented part. those shavings could ruin your new pads and/or your wheels
Quick Reply: baer claw gt rotor question
