valvetrain question
valvetrain question
Ok my car has a 355, stock headed with sa 1.6rr, cc503 cam, and full rebuild in it, it dynoed 343hp at 5400 and 362tq at 4600. Problem is at 6000rpm power falls off its *** on the dyno, but it feels strong all the way to 6500, but also has an occasional break up above 6000rpm so I have quit pushing it past 6000. My question is I want to upgrade my rr with nsa stuff to try and help, am I doing right or is my cam just giving up.
Are you running stock valve springs?
If you are, I would strongly recommend getting a good aftermarket set. Stock LT1 valve springs are nothing special and will float a bit when pushed anywhere past stock red line.
I'm on a stock cam, but gained roughly 3.7mph in the quarter just from doing Patriot valve springs and Comp NSA rockers and hardware.
Best trap before springs and rockers was 107.2
Best trap after was 110.9.
Same exact weather, track conditions, tires, 60', everything.
I don't recall the scecs on the cam they were recommended by le for that cam I have no way to check dc on the objectors is,there a scanner that will tell you that stuff
