12 Second Club - 12.812 @ 108 through manifolds/cats
SLP IROC-Z
07-20-2011, 11:37 PM
took my 99 back up to the track tonight to see what the 9" and 4.10s did for me, best pass was 12.812 @ 108 with a 1.840 60ft on et radials DA was 1900'. also ran 12.823 and 12.863 (spun). best 60' was 1.826 but missed third, def would have hit 12.7x
previous best was 12.935 @ 107.33 with a 1.89 60', 1130 DA with stock rear.
3650 race weight. car has lid, descreend maf,pptb, slowhawk mail tune to fix maf curve and cat back. hopefully we get some cooler weather, id like to see how quick i can get this car to go without doing anymore mods.
blk/slvr02ss
07-21-2011, 05:43 AM
Not bad for your Mods but u need to get your 60 ft times down in the 1.6's and u should b good for 12.50's !
ramairetransam
07-21-2011, 07:34 AM
good mph for the mods , very strong car.
jetaws6
07-21-2011, 07:36 AM
Ls1 intake or ls6 intake?
SLP IROC-Z
07-21-2011, 12:16 PM
yeah i need to get lower control arm relocation brackets, getting a little wheel hop out of the hole. still running the stock clutch and driveshaft so i really dont want to push it too hard either.
SLP IROC-Z
07-21-2011, 12:17 PM
stock 99 intake.
blk/slvr02ss
07-21-2011, 01:41 PM
A Adjustable Torque Arm will make a big difference also !!!!!! I was Cutting low 1.6 's w/ Nitto 555R's w/ Auto Bolt-on Car and everyone says those tires suck so i would say the Torque arm really helped !!
jetaws6
07-21-2011, 02:23 PM
stock 99 intake.
Id say your times are pretty damn good then for your mods. 12.8 with a descreened maf and catback for your only mods
SLP IROC-Z
07-21-2011, 02:48 PM
thank you, it seems like a strong car. the 4.10s definitly helped as you can see im quicker et wise and pickd up mph even though the air was a lot worse. just need some cool weather and lca reloc brackets.
jetaws6
07-21-2011, 03:32 PM
I missed that you had 4.10's. What size wheel and tire are you running then? You should be able to get that 60' to a 1.7 at least on a pretty much stock motor
SLP IROC-Z
07-21-2011, 04:57 PM
i was running 255-50-16 MT ET radials on salad shooters. no doubt it has potential to 60ft harder but it definitly needs reloc brackets for the LCAs to do it, it gets some hop out of the hole.
Fast T
07-21-2011, 10:09 PM
Congrats . Work on that 60ft and you should be right were you wont to be:judge:.
