Cadillac CTS-V - H/C CTS-V: Feels Slow
z28C4maro82z
07-21-2011, 04:04 PM
Well here goes.
I have an 05 V
Mods:
232/240 .618/.624 114 cam
Patriot stage 2 heads
OBX Longtubes
X pipe
Muffler delete
B&M Shifter
K&N Intake
Car was street tuned, my buddy tunes for RPM. Still waiting to get on the dyno for a full tune.
However, the car feels SIGNIFICANTLY slower than my old cam only z28. I don't know what to do, I know there is a big weight difference. But, the car just feels like it barely moves. To me it feels no different than before the heads cam
FRiCK
07-21-2011, 04:24 PM
I don't see a tune making a car feel like there's something majorly wrong. Are you sure the cam is in there right?
JNR_Design
07-21-2011, 08:03 PM
Yeah, how was the cam degree'd when installed (ret/adv deg?)
Did you get this car already modified? It's kind of hard to tell on your description, but the way I read it is you picked up a modified V that got tuned, but feels a lot slower than your Z28 that had an upgraded cam...There is a lot of missing information and assumptions/subjectiveness is left to the reader, so can't answer your question as-is.
The car will feel slower sensation than an F-body apples to apples, but with those mods, considering they're done right and everything working properly, it should still feel faster, I would think. We have 3.73 gearing to compensate for the weight, but the build and tightness is where the sensation gets drowned out somewhat...
lubelizard
07-21-2011, 08:29 PM
LS6 with large cam and large heads results in lousy low and mid rpm torque. You'll have to rev hit higher, but it needs a dyno tune before you beat on it. How are you not being stopped by cops for what I see as a loud exhaust?
98cobra
07-21-2011, 08:59 PM
A heads cam cts is slow. Unless you have well over 500 to the wheels, the car will still be pretty slow.
JNR_Design
07-21-2011, 09:02 PM
Funny how the definition of slow has transgressed...:D
btw - if you ever had to push a car, you can appreciate the work the engine is doing to propel these 'slow' cars so fast, hehe...
itsslow98
07-21-2011, 09:20 PM
I agree, any first gen V will be slow without a power adder, unless you go 427 and a badass heads/cam package. Even a 408 is gonna be slow. Only reason mine feels fairly quick is because of the nitrous. 510lb/ft at 3k rpm feels pretty good and helps to get it moving.
Hate to say it but a cam only f body is capable of high teens trap speed, your heads/cam V might go 115.
z28C4maro82z
07-22-2011, 01:47 AM
I ran 119.99 trap speed in the fbody.
I bought my car stock, did all the work myself. There was no timing retard or advance. The tune is run with bumped up timing, my buddy tunes for RPM he did a full street tune.
IDK, just not as happy as I would have expected to be with the whip. I know it's 4000lbs, but thought it would have a little more to it
z28C4maro82z
07-22-2011, 01:53 AM
I really haven't been bothered. Trust me, I drive very spirited too lol. Don't jinx me
itsslow98
07-22-2011, 01:54 AM
Throw a bottle on it and youll be satisfied. After I did the cam I knew for a fact doing heads/fast intake would be a complete waste of money, just jet it to 150 if i wanted more.
The 93 coupe i built/building is the reason why the V will get zero mods from now on, itll be a car with a ton of potential, hell with 400rwhp itll go easily 2 seconds faster and trap 5-10mph faster then the V on the bottle.
z28C4maro82z
07-22-2011, 02:06 AM
I had a 5.0 I was going to lsx swap. Oh well, I'm sure once the clutch gets swapped out for the one in the trunk now I'm sure the SOTP feel will be a little greater and feel a little better revving quicker. We'll see, just not happy with it 100%. I know on the street tune it was tuned on the stock box and everything. Above 5500 rpms I'm not getting enough air so it's detuned a little I believe. So the cam really kicks in around 4200. We'll see maybe a fast, and now the K&N I have now will help. Other than a fast I probably wouldn't do much else.
98camaroLS1M6
07-22-2011, 08:21 AM
See what it makes after it's tuned. It is 100*F outside and that slows every LSx car down a good bit. If it's still not making good power, I would try a smaller cam on a tighter lsa, and a set of tea TFS heads.:nod:
z28C4maro82z
07-22-2011, 08:57 AM
Yea, I know the heat but it;s felt like this since I was done the install. I think the clutch slips on hard shifts too because the rpms seems to float and drop so that may not help. We'll see in the end lol
big reg
07-22-2011, 09:41 AM
Try going from a whippled cobra to a v. Now that makes it feel slow.
98camaroLS1M6
07-22-2011, 11:23 AM
Well get that thing on the dyno and see what's up. I know my untuned H/C setups felt slow but that was only because it wasn't tuned. As long as something isn't mechanically wrong, I think it should make good power:nod: 440rwhp should be enough to trap 118+mph in cool fall air.
big reg
07-22-2011, 01:15 PM
Not to mention these cars have horrible transmission gearing. There isxa huge gap btw 3rd and 4th. All the newer German sedan are heavier but have great gearing. Most have 7 gears all of which are used for acceleration. The v has 5. I hate that gm markets most of their cars as 6 speed manuals. They are 5 speeds with overdrive. With a true 6 speed tranny it would be so much faster.
06killerv
07-22-2011, 01:24 PM
not to start a fire but if your worried about ET's and trap sppeds in a V1 you but the worng car its a performance sedan that was build to make turns not to be launched at 4,000 rpms and ran wide open for a few short seconds yes you can take your v to the track and have some fun everyonce in awhile but it is not a weekend warrior people with M5's (what the V was designed to beat) dont drag race either drive it enjoy it let people be suprised by it on the street,go by a mullet car to drag race in....sorry i had that pent of after reading alot of posts recently
NeverSatisfied02
Big reg... Coming from a stock eaton cobra with upper and lower pulleys still makes the V feel turd slow lol
JNR_Design
07-22-2011, 07:44 PM
If you want to get technical, it's a 4-speed with two overdrives, or a true 6-speed manual transmission...I don't care how many gears the german cars have, 'cause each one of those would be $$$ to replace (and it'll happen) :D I've never had any issues with 3rd to 4th as far as gearing go, but between 4th and 5th there doesn't seem to be much change. Besides, we have a dual mass (heavy) flywheel, so I bet with a regular billet steel (screw alum. in a relatively low revving, relatively heavy car), it would feel so much different.
These cars are not drag racers and if you want something fast, build a BB turbo chevelle or something; you want something wicked fast and scary, build a 800 hp Cobra or Viper or on those lines :)
This car is a great daily driver that does everything well (for stock) and not much else on the market off-the-shelf that will do it like that and esp for a low price. Fast and Slow is a relative term and I don't care how fast it is, I wouldn't want to own half the supposed "fast" car platforms, that everybody else has done 10X, but that's me...I used to be into 'fast', but anymore, if it has the styling, chassis/suspension setup with good power and has the option to improve upon, good enough for me...
There's nowhere to safely excercise the car anyway, even here with open roads and high speed limits, but know the urge. Problem is, the stuff I see people do just to go 'fast' and the way they go about it (cause many of them are young, inexperienced, don't care, don't have the budget, whatever) is not cool when you consider there are other people on the roads and that thing you created was never intended to do that, let alone somebody check thru it, etc...Anyway, not trying to rant, but just saying that things need to be thought thru an there is a huge gap between the real cars that can handle the speed and motions and those that should be 10X more careful...
Still, I wouldn't mind having a supercharger and all that, but my money is better spent on something that will perform like crazy (power and hooking up)...I actually have more fun in my VR4 and while it puts out just a little more power than the V, it weighs 600 lbs. less, has really tall gearing and of course AWD, so when it goes, it goes...Almost scary :D Same thing with the 'velle, with 'only' 600 hp or so, it could be in the low 11' or high 10's with proper suspension, and sound better doing it too; I like these new age LS engines, but they don't compare in sound to the older stuff and especially the BB's...But, they don't sound bad either and nice to get power so easy, if you want to spend the $.
liqidvenom
07-22-2011, 08:46 PM
1) the v1 raced in a series where you did standing starts, so it isnt odd to see a performance sedan having to launch itself.
2) the V isnt in the m5's class, might perform similar but they are different cars hitting different targets and buyers. but M5 people use the launch control on their vehicles to drag all the time. even the e39 m5 can be seen at the drag stip.
vmapper
07-23-2011, 12:19 PM
If you want to get technical, it's a 4-speed with two overdrives, or a true 6-speed manual transmission....
Correct!
First:2.97
Second:2.07
Third:1.43
Fourth:1.00
Fifth:0.84
Sixth:0.57
Reverse:2.9
whitew01ws6
07-23-2011, 01:41 PM
Hey what did u do with ur old heads... Pm me.
vmapper
07-23-2011, 06:15 PM
If your talking about the OP, they were in the classifieds some time ago...
98cobra
07-23-2011, 08:23 PM
Thats why I rev to 7k from 3rd to 4th, otherwise my 408 drops out of its powerband. 480 wheel and a being a tank dosent do much for me. It is fun to drive at least.
07CTS-V
07-25-2011, 09:52 AM
My 418 doesn't drop out of the powerband from 3-4 at 6200 rpms. Maybe it's the extra 33 to the wheels. :devil::devil::devil:
98cobra
07-25-2011, 10:12 PM
33 hp? You might pull half a fender with that. Still leaving you with a slow car.
itsslow98
07-25-2011, 10:29 PM
^ Your both slow, N/A V1's FTL.
P.S. I am not saying I am fast by any means.
aurora40
07-26-2011, 07:48 AM
If you look at the ratios, 1-2, 2-3, and 3-4 are all exactly the same gap. Each of those shifts will drop the revs down to 70% of what they were before the shift. 4-5 is a very small gap at 85%, and 5-6 is about like the others @ 67%. 6th is shorter than on most GM 6-speeds, and the 3.73's help too.
I think 6th is a performance gear in the V, I believe it's needed to reach top speed? 5th will run out of revs around 160mph I believe.
Derek98z
07-26-2011, 10:43 AM
Check fuel pressure with a gauge. I'm going to guess when he tuned it, he watched the fuel trims but you never know.
Have you cleaned the air filter in a while. Believe it or not, I saw a freshly built Camaro that had an old filter on it and ran like dogsht. Replaced the filter and felt like it added 100 horses.
Did the heads come fully assembled? I've also seen a set of dual valve springs where the valve seats were not replaced. This dual spring did not sit on the seat properly and the car ran like crap due to bind. Also, are the rocker arms overtightened?
big reg
07-26-2011, 03:03 PM
I think 6th is a performance gear in the V, I believe it's needed to reach top speed? 5th will run out of revs around 160mph I believe.Actually top speed is achieved in 5th. You need a shit ton more power than stock to accelerate above 163 with the stock rev limiter in 5th. Either way the V1 is a huge disappointment performance wise for me. I cannot drive a car that feels like it will break if I get on it nor do I want to keep changing bushings, mounts etc... I tried to save money by purchasing this car but it will be sold shortly once I am settled in my new job for a newer sport sedan. 117mph traps with a 513rwhp car. Lmfao :eyes:. They look awesome and I get tons of compliments especially with the wheels but overall have been left disappointed with this car. :ripped:
For comparison sake. IS-f with 415rwhp = 120-121 traps. E60 M5 with 410rwhp stock traps 116. C63 with 415-420 is also a 120+ car. Guess why. exceptional gearing. :nod:
vmapper
07-26-2011, 03:20 PM
I know were you are comin from... the edge of feeling something is going to break on ya...
stock does ~112 having 350rwhp
+125shot n2o does 124mph.
http://www.youtube.com/watch?v=JrbZo4mTR18&feature=related
aurora40
07-27-2011, 07:36 AM
All of those cars you mention have close to 100whp on a stock V1 (320-330whp).
That said, it does seem like the best way to enjoy these cars is stock. Sink a lot of money into mods, and it sounds like it can be disappointing.
z28C4maro82z
07-27-2011, 08:08 AM
Hey, I'm still happy with the car don't get me wrong. I just think that the car should feel more than what it is now. I really think a lot of the disappointment is in the clutch, and how slow it revs. They did a junk job on that. On the agenda in August is to switch the clutch.
vmapper
07-27-2011, 09:35 AM
Stock for an IS-F is 350rwhp not 100+ on a V1. (more like 20)
I think the point was that when you get your V1 up to those stated levels, the mentioned vehicles pull good traps vs a 400rwhp V1.
