General Maintenance & Repairs - Weird ping noise + Service engine soon on
Camarosteve44
07-21-2011, 06:18 PM
Today i was cruising back from the beach, i was on the parkway going a consistant 70-80 mph. Randomly my service engine soon light came on. Shortly after, randomly a squeak/ping noise would happen some where on the drivers side of what i think is the engine bay and the car would like bog/slow down 5mph immediatly. This happened around 5 times.
Not sure if this makes a difference, but when i was pulling out of the parking lot, i misjudged the exit and scrapped the y pipe(non stock) pretty hard.
Let me know what you guys think/what i should do.
2001NBMZ28
07-21-2011, 06:33 PM
See what the code is, even if it's not on now it'll be stored. Just guessing but you might have damaged an 02 harness.
Camarosteve44
07-21-2011, 06:49 PM
P0032 is the error code. Google shows o2 sensor. Guess i damaged it wheni scraped the y pipe.
Camarosteve44
07-21-2011, 08:16 PM
Also, how long can i run the car like this as it will take a few days to get the new 02 sensor in
TImmy_Jones
07-21-2011, 10:22 PM
Don't run the car anymore, it is bogging because it is running SUPER RICH - which is fine for the engine, but the spark plugs will most likely need to be changed on that side.
BlackScreaminMachine
07-22-2011, 07:02 AM
Get it fixed and yes you either damage the O2 itself or part of the harness. Most likely if the car is stock its the down stream o2's (rear) but do a visual and since your doing them you have to get them all done so you don't have one reading lazy and a brand new one working fine.
Thats no good either.
