SS wont start-pop hood-starts?
Old 07-22-2011, 07:22 AM
SSsuperdave's Avatar
Default SS wont start-pop hood-starts?
That's it in a nut shell. I had an intermittent no start condition and it seemed that when I wiggled the shifter it started. Coincidence I believe. So then it got worse about not starting. So I bust out the ol Helm book and trace the circuit out. Checked the clutch switch, good, checked the starter relay. 86 had a good ground to BCM. 85 had voltage from key in crank position. 87 had battery voltage. 30 toned out to the connector on the pass side fender that goes to the starter solenoid. Pulled starter, cleaned residue from block and starter mounting surfaces. Cleaned rusty corrosion from solenoid post. Verified voltages at starter. Reinstall, rock and roll. Now its doing it again and this is the confusing part. Get in, turn key, nothing. Only thing I do is pull hood release, that's it, don't get out car, wiggle shifter, nothing. Turn key immediately thereafter and it fires. Like clock work now every time if fails to start, pop the hood latch and fires. Get out push hood back to latch. Followed hood cable, it dose not touch anything. No
wording,wiring
