Will COnvertible 3 pt Sub frame connectors work on my Hardtop??
Old 07-22-2011, 10:49 AM
Nastyc4's Avatar
Default Will COnvertible 3 pt Sub frame connectors work on my Hardtop??
Was looking at a pair of Subframe connectors for a Vert they are a 3 piece triabgular design. I know the 3rd point doesnt reach as far in as the coupe 3 point connectors will they still be able to be fitted to a coupe? My car is an 02 Hardtop. If I can weld all 3 points under the car I'll buy them. If not I'll just buy regular SFCs for a coupe from UMI/BMR etc.
Old 07-22-2011, 11:39 AM
UMI Performance's Avatar
The convertible set will most likely not work on your hard top.
I hope that helps,
Ryan
Old 07-22-2011, 12:41 PM
Nastyc4's Avatar
I am guessing the floorpan is different where that 3rd point on the vert sfc weld to? appreciate the reply Ill probably be ordering a pair from you soon
Old 07-23-2011, 01:49 PM
Actually the center mount is the same. But the floor does have extra bracing that causes clearance issues, the front and rear mounts are a little different.
Keep us in mind when you are ready
Ryan
