12 Second Club - 1st runs with cam and converter
Gunrock_T/A_0811
07-23-2011, 01:08 AM
12.62 @ 108mph on a crappy 1.88 60ft. time for suspension!
LS1rob00
07-23-2011, 02:41 PM
Congrats on the time, you should be going quite a bit faster though permitting the DA wasn't anything crazy. Were you on street tires?
d98gt
07-23-2011, 05:20 PM
Which track? Congrats on the 12s
Gunrock_T/A_0811
07-24-2011, 05:13 AM
DA was way high, didnt calculate it but I'm stationed in jacksonville, NC right on the coast with humidity worse than houston. Track doesnt prep for tnt and doesn't have a good layer of rubber down. I wish I could upload the go pro vids but youtube isn't working or just takes way too long for a 1080P file. I'm running toyo proxes TQ, stock susp. 60ft wouldnt go under a 1.88. Launch is good, not spinning that bad but then again this track with slicks dudes spin so I expect it. Launching off the converter at 2500, tried to push the rpms up a little but the brakes wouldnt hold it jumped.
Gunrock_T/A_0811
07-24-2011, 11:28 AM
just calculated the DA and it was at 1900 to 2200 ft throughout the night.
s346k
07-25-2011, 08:32 PM
sounds like the car could use a little tlc. i went 12.7s on 245 goodyear gscs with a bolt-on ls1 in worse da.
who tuned it?
Fast T
07-25-2011, 09:32 PM
Congrats on your new sit up and ET:nod:.
projectX
07-25-2011, 09:38 PM
With cooler weather you will be rockin out!
1Bad97WS-6
07-25-2011, 10:36 PM
Get that 60ft down to 1.5 to 1.6s and you would be good.
Gunrock_T/A_0811
07-27-2011, 07:19 PM
yah I know, new torque arm from UMI is coming....just gotta get the cash saved up because I want a new panhard bar and LCA's to go with. think the car will 60ft on a better track. Going to be spraying soon, its just too damn hot to work on the car and I am super busy with work all the time. Train train train is all we seem to do in the marine corps.
2fresh
07-27-2011, 08:30 PM
yea i go a 12.6 @110 on that track on a 1.9 60 no cam or stall who tuned it?
slayer performance
07-27-2011, 08:34 PM
not bad for a lil 5.3
WheelsUp84z
08-05-2011, 09:28 PM
I just noticed that in his Sig too, makes a little more sense now.
To the OP. You should check out our local site www.rwhp.us Lots of fbody guys on there. We're all out of Jacksonville/Havelock area. We're going to the track Aug 12th if you want to meet up with us. I'm Juiced91Z on the boards.
01 4.8
08-06-2011, 11:41 AM
Congrats on the times, I thought about putting a 5.3 in my car just so I can play with it untill I can build a motor. Whats the weight of your car?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
