General LSX Automobile Discussion Non-technical LSX related topics.
ws6 to c5 ls1 swap help
Old 07-23-2011, 09:53 AM
alexgio1989's Avatar
Default ws6 to c5 ls1 swap help
i just picked up a corvette c5 with a bad motor. going to put the stock ls1 from my ws6 into it. is there anything different between the two motors or is it a direct swap? any info will help thanks!
Old 07-23-2011, 09:57 AM
Hashish's Avatar
Should be the same motor, may have different intake/heads depending on the year of each engine.
Old 07-23-2011, 10:16 AM
ok thanks alot hashish thats what i figured but i wanted to double check before i start to tear down
Old 07-23-2011, 04:52 PM
Camaro_94's Avatar
Pretty sure thy have different oil pans. You can prob take the pan off the C5 and just reuse that.
Old 07-23-2011, 05:30 PM
Steve01SS's Avatar
Yeah, the oil pan, and all the engine accessories/ tensioners and brackets will need to be swapped.
Also you must swap over the harmonic balancer from the C5. The belt will not line up if you try and use the f-body one.
The motor itself the same.
Old 07-23-2011, 08:19 PM
T-Top's Avatar
Wacha doin with the ws6....?
Old 07-23-2011, 09:05 PM
lees02WS6's Avatar
isn't the throttle body operated electronically on the corvette?
Old 07-24-2011, 03:46 PM
SupraNatural's Avatar
Yes it is.
You need to swap the throttle bodies.
Old 07-25-2011, 06:52 PM
02fbody35th's Avatar
the vette uses different exhaust manifolds as well
Old 08-01-2011, 12:20 PM
i bought a 6.0 iron block for the ws6 its in the machine shop as we speak being stroked out
