stock ls1 only get 200 miles to the tank... WTF??
Old 07-23-2011, 11:20 AM
klutch-'s Avatar
Default stock ls1 only get 200 miles to the tank... WTF??
So my car all of a sudden started getting shitty, VERY shitty fuel mileage. Seems to be a little sluggish at times to.
Sometimes when im just cruising down the road at like 65 the car acts like it wants to surge? Idk it like loads up and jumps a little. Idk how to explain it lol thx for any advice.
Old 07-23-2011, 11:29 AM
solidsnakecsm101's Avatar
Have you done a recent tune up? Start off with the small stuff like tire pressure, wires, plugs, and fuel filter. My car, 01 M6 Camaro with 3:42's, gets anywhere between 350-380. I have to baby it though. Autos might yield lower numbers.
Old 07-23-2011, 01:05 PM
sjsingle1's Avatar
no codes?
Old 07-23-2011, 01:36 PM
JrodCamaro's Avatar
Interesting I was just having this on my mind, also started to act a little weird (i think my clutch is starting to slip just a bit thou) But was curious on the MPG, finally babied it on this last tank and got about 280 out of it, mixed highway/city cruising at 70 and a few romps on that giddy up pedal. Is it an A4 or M6?
Solid that 350-380 is insane, I'd kill to see that out of my car. Best I ever got on my 97 V6 Camaro was only 340
Old 07-23-2011, 02:36 PM
The 350-380 to the tank is obtained during long highway drives up to Northern Cali and thats with me cruising at 75. When doing City/highway i would get around what your getting 290-320. You really need to baby these things to get the most out of the city mpgs but i cant complain with the highway results.
Old 07-23-2011, 05:11 PM
JrodCamaro's Avatar
Oh ok, I kinda wondered but haven't tested it yet. That sounds like good numbers, in 2 weeks I'll be making my first long range trip so I'll have some numbers then. I still use skip shift, and either straight to 6th or 5-6 trying to preserve what I can. These can eat your wallet if you're not careful, noticed that real quick
Old 07-24-2011, 08:03 PM
FiredUpZ28's Avatar
Miles per tank is kind of a bullshit way to determine gas mileage. Did you fill the tank all the way or did it only need 3/4 tank, 1/2 tank?
Fill up, reset trip, drive, fill up again, do the math. Its the only way to guarantee anything. Having said that, if there are no codes than I'd be willing to bet my lousy salary that its your driving habits eating so much fuel.
Old 07-24-2011, 08:34 PM
LS6427's Avatar
02 sensor(s) are on their way out.........
Old 07-24-2011, 09:11 PM
baalic's Avatar
My v6 gets about 440 miles per tank on a weekly basis. That's 90% highway though.
My 6 speed TA with all in town is about 250 but on all highway i did over 400 twice...
Old 07-24-2011, 09:17 PM
MillerTime85's Avatar
x2.Does exhaust smell a little rich?
Old 07-24-2011, 11:04 PM
HAZ-Matt's Avatar
LTs + stall don't help my city mileage any...
Sometimes I wish I had swapped in an M6 instead of getting the stall and the 4L60 built
But anyway, good suggestions above like tire pressure. You need to check the usual suspects. O2's getting old could tank your mileage.
Old 07-24-2011, 11:10 PM
gavin2005's Avatar
get a scantool on there and check your 02 data and air/fuel
Old 07-24-2011, 11:43 PM
f-body.cbct's Avatar
My M6 gets about 250 to the tank with mostly city/some highway.
Old 07-25-2011, 03:03 AM
01ssreda4's Avatar
MAF or O2s I'd bet.
Old 07-25-2011, 04:48 AM
baalic's Avatar
Oh mine both run 90 octane, 91 when I can find it... 93 when I'm places that have it
Old 07-25-2011, 05:21 AM
Chrisingermany's Avatar
Mine bucked every once in a while so I cleaned the MAF and hasnt done it since
Old 07-25-2011, 05:50 AM
officerobrien55's Avatar
Default clogged fuel filter
could be a clogged up fuel filter, n could be bad knock sensor, ya it should show up on the engine light. my buddy has a 04 gmc truck throwing his knock sensor and when it does he goes from upper teens in gas milage to 10 0r less and has no power. but hell how knows with all this computer controled stuff.
Old 07-25-2011, 11:42 AM
LS6427's Avatar
Leaky fuel injector can kill mileage too....but you'd have some level of misfiring and backfiring, usually. Unless it only leaks in the upper rpm's where it can eat up that extra fuel getting into the cylinder. Just a thought though.....
Old 08-24-2011, 09:41 AM
Pabbi's SS01's Avatar
same here, i get 400mi a tank driving 65-75 flucuating with speed of traffic. Every time. last trip up took to north cali from san diego with a few runs with a cobra and still got 400mi on a full tank. figure out whats messing with your air/fuel or take off that e-brake!
Old 08-24-2011, 10:53 AM
thunderstruck507's Avatar
This.
GM fuel gauges are all over the place. Calculate MPG to see how bad the problem really is...if there is one.
Quick Reply: stock ls1 only get 200 miles to the tank... WTF??
