Small Bore LS7 heads on 402 LS2 What is Needed, Whats Not
Im looking at possibly installing a set of RPM 4.00 small bore LS7 heads on my 402 as well as a port matched/cleaned up LS7 Intake. I was curious as to all the parts I would have to replace in order to get it all to work and what parts I can just swap over from my current setup. If anybody has more info for me that would be awesome.
So far I know I'm gonna need/swap out;
LS7 Intake Manifold
LS7 pushrods
LS7 Rockers
What I dont know about;
Are the TSP headers I have the right size/fit for those Heads?
Do I Need to Replace my LS1 Fuel Rails/Injectors? I believe there are adapters for the injectors to work.
Do LS1 Valve covers fit over 1.8 rockers or do I need spacers and or modifications to make them work.
Fast 92mm TB should fit right?
I'm sure I'm missing stuff so I figured I'd ask on here and see if someone with more knowlege could help me out. Thanks
LS7 Intake Manifold
LS7 pushrods
LS7 Rockers
LS7 heads have a D shape exhaust port, I don't know if the small bore LS7 do or not
If your fuel rails are stock LS1 rails, then yes, and if you have stock injectors I doubt they will keep up with a 402, replace them with some LS3/LS7 injectors.
They will need modified to fit, you have to take the baffles out of them
I think so
Don't forget that the LS7 manifold has no provisions to mount the throttle cable bracket, you will have to make a bracket or buy one, slp makes them I think.
I think so
I think so
I think so
So far it all seems like minor/cheap things that I will need to do. I need to find out about the headers. I would hate to have to buy set of headers again just to accomidate heads as my headers are 2 months old.
I would just love to have awesome flowing heads and intake which are both known to have good velocity and also to be different.
Thanks for the help!
I just think there is a lot of gains to be made, atleast for me. Considering I would have to spend atleast 3k on some TFS heads + rockers etc why not spend a tiny more for 380+ CFM heads and a proven intake.
I dont see where it cant make a bunch more power. I'm really hoping there is a nice amount of HP to be made with this setup and a big cam.
