Those running a 4l80e with 4l60e segment and relay.
All the wiring is done... nothing has been done to the tune... I only have second gear and reverse... will the codes have to be overriden to get this thing to shift right? Or is there something else wrong?
Update... I had been trouble shooting this for a while slow67 helped me out quite a bit... explained what the trans needed to operate. I had it wired up right but the relay was not switching signal to ground 3rd. Replaced relay and all problems solved. Truck runs like a champ. Can't beat this way of running the 4l80e.
Anyone care to share how to do this, I got my 4L80E running today and I hate the unlock when at zero throttle, then locks again with throttle. Id rather it operate like a 4L60E lockup.
drive TCC PWM using TCC Enable, or gate TCC PWM thru a relay controlled by TCC Enable.
Also I suppose the codes need to be set to 3 No error Reported?
Thanks, thanking about making this swap.
