Racetronix FPWH-017 Fuel Pump Wiring Kit MP150/280, Generic
Category: Engine - Intake/Fuel
Price: $70
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): IL
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
I am no longer going this route and do not need this kit anymore. This kit is brand new and never even opened!
$70 shipped to your door!!!
Info from Racetronix website:
This kit has all the parts required to upgrade the factory wiring on GM factory vehicles equipped with the older-style 4-position 150-series fuel module connector to the new-style GT-series connector system. The older-style 150-series connectors are known to fail over time so GM/Delphi has switched all new-production modules to incorporate the GT-series connector system which has twice the current capacity. This fuel pump wiring kit is a must when upgrading to new high-performance pumps which draw 2-3 times more power than a factory pump.
This fuel pump wiring kit contains the following items:
* Racetronix Fuel Pump Upgrade Harness FPWH-017 - Provides a heavy-duty power source for high-performance pumps (up to 30 amps). This harness adapts the older 150-series connector to the new 280-series connector without the need for external adapters or splicing.
* Fuel Module Electrical Bulkhead Connector Kit RCS-028 - Direct-fit 30-Amp rated connector replaces factory 14-amp unit.
* In-tank Teflon wiring harness ITWH-022 - Direct hookup between Delphi connector and Aeromotive and other aftermarket pumps. (Positive terminal on right when pump's outlet is held at 12 o'clock.)
