Conversions & Hybrids - accessory drive set-ups
View Full Version : accessory drive set-ups
jozw30
07-24-2011, 04:56 PM
Need to move the alternator and AC compressor up top (2006 GTO motor). The GMPP stuff looks like a good value, but will be going with Vintage Air or other aftermarket AC/heat system (55 Olds 88).
Has anyone pieced together a set up like this adding on a Sanden or other compressor that works with the aftermarket systems?
I can't afford one of the $2K drive systems.
Thanks!
Joe
Project GatTagO
07-24-2011, 04:59 PM
Order the GM kit without AC. It will essentially be a C5/C6 setup. Then get the Kwik mount for the Sanden.
Andrew
jozw30
07-24-2011, 07:41 PM
Perfect! Thanks Andrew!
Joe
garys 68
07-25-2011, 02:31 AM
I made my own brackets for high mount on my first motor, but bought the Kwik AC bracket on the 2nd.
http://www.ls1tech.com/forums/conversions-hybrids/1039164-simple-accessory-drive-done.html
