Convert Power Seat to Manual Seat??
Old 07-24-2011, 05:45 PM
YURVIEW's Avatar
Default Convert Power Seat to Manual Seat??
Does anyone know if it is possible to switch fbody power leather seat over to a manual seat?? Curious as to if the seat brackets can be swapped over from manual seat to power seat, and anything else would be needed and/or prevent this from being possible. My driver seat has a bad wire or motor or something, keeps blowing braker fuse. Wanted to see if this was option before buying some race seats. Thanks!!!
Old 07-24-2011, 06:12 PM
LS14EVR's Avatar
I wouldn't think that would be an issue. Should bolt right up to seat pan. I work for a seat manufacturer. Let me know if you have any issues.
Old 07-24-2011, 06:21 PM
pir7tr's Avatar
I swapped without any issues. Bolted directly in.
I went from power leathers to manual cloths and left the power connector under the seat.
Old 07-24-2011, 06:35 PM
YURVIEW's Avatar
No no, Pir7tr. I talkin about takin manual seat mounting bracket and puttin it on a power seat..... not swapping entire seats.
Old 07-24-2011, 07:11 PM
pir7tr's Avatar
Ahhhh....I see what you are doing now.
I would imagine it can be done. If you plan to keep the same style seat, mounting a manual bracket to an original power seat should not be different IMO. I bet they are mounted the same way difference being one has a motor. I am curious to know now! Now if you were going from a TA power seat bracket to a camaro manual seat bracket that might be different.
Old 07-24-2011, 09:06 PM
badfbodyz's Avatar
seat brackets are the same manual or power.
Old 07-25-2011, 12:11 AM
FastRidesOnly's Avatar
i wanna try something similiar.
might try it tomorrow..
i wanna take my stock 93 z28 drive seat and take the power parts and swap it to the trans am vinyl seats that i have, i got them at a junkyard, passenger is already power, driver seat is manual. guess the person that put that had them before me found one out a manual car then one out of a power car.
Old 07-25-2011, 06:52 PM
fbodyrs96's Avatar
Early model TA's had manual seats with lumbar controls.
Quick Reply: Convert Power Seat to Manual Seat??
