Plate vs Fogger Nozzle?
so on a 200 shot NX Kit am i better off upgrading to the ls1 plate or will i see no gain over the nozzle the kit comes with?? and also do i need a window switch or can i just use the little adaptor box that works off my drive by wire it works off the tps signal??
Guest
Posts: n/a
Its the limitation in flow. Its the ability of a nozzle to distribute it properly between cylinders.
Most 1/16th nozzles will max at around 150.
Most 1/8th nozzles will max around 250.
Again that is just the limitation of the flow on these.
