Devils Own meth Pump Best pump on the market!! $100 bucks shipped Used once!!
Category: Racing Parts
Price: $100
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): WY
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
This pump is the highest PSI pump available on the market. These will help achieve the smallest micron droplet size possible. Internal bypass design results in superior flow at higher pressure than pumps using an external cut off switch.
* Pressures up to 250 PSI (17.2 bar)
* Self priming up to 8 vertical feet (2.4m)
* Chemical resistant materials
* Can run dry without damage
* Designed for heavy duty methanol injection systems
* Built in reverse check valve
This pump delivers 1.0 GPM open flow, EPDM /Nylon valves, Santoprene diaphragm, and adjustable peek pressure from 150 to 250psi. (Factory set to 200psi) Intergrated 1/4" push to connects, with a poly housing while having a low 10amp current draw. These water-methanol pumps are extremely durable, and will most likely outlast your car.
While this pump is chemically compatible for use with 100% methanol and/or ethanol, we do not recommend running flammable liquids.
$100 Shipped Its as good as NEW!!
Call/Text/PM 307 267 1281
