wiring screw up
Old 07-24-2011, 11:26 PM
mrmckeehan's Avatar
Default wiring screw up
Me and my brother are doing an ls1 swap in my 01 camaro. well we got in a hurry and didn't tag all the sensors. I was wondering if someone has came up with a write up and color codes of each connector. we are about to put the new ls1 transmission and engine in the car and are going to start wiring it up.
Old 07-25-2011, 12:54 AM
98SSClone's Avatar
Do you have a wiring harness and PCM for an LS1 Camaro? If you're starting with a V6, you need the LS1 engine/trans harness and the PCM.
You'll also need to swap the K-member.
It really helps if you have the donor car the LS1 came out of.
Old 07-25-2011, 11:56 AM
mrmckeehan's Avatar
i just basically need to know where each connector goes...like i have seen a list of connectors and stuff for a m6 but i need one with an a4.
Old 07-25-2011, 02:34 PM
oldmano2z's Avatar
a4 has speedo sensor,and a big multipin plug,and some rear 02 sensors
Old 07-25-2011, 03:09 PM
the_merv's Avatar
Show us a pic of what you want to know..
Old 08-12-2011, 10:58 AM
mrmckeehan's Avatar
basically all i need to know now, is basically on each head, on the back there are 4 bolt holes..I know on the left side 2 of them are grounds and on the right is the transmission dipstick. what all goes in those spots? i was a dumba** and didn't take pictures of the back or anything. -_-
Old 08-12-2011, 01:45 PM
mrmckeehan's Avatar
can anyone help me....lol sorry for being impatient, i am tryin to get it done today.
Old 08-12-2011, 02:08 PM
t/a98's Avatar
Bolts are blank the heads can fit left or right the same so they drill the same holes on the front and back of all heads and only use some of the bolts on each side.
