No internal work LT1
Old 07-25-2011, 12:23 AM
i E i's Avatar
Default No internal work LT1
What kind of power can be expected Rear wheel wise, with all mods besides internal work? And a list. Also, I just mean no boring it out, no forging, that kind of stuff... until later. thanks
Old 07-25-2011, 04:24 AM
lt1slowz28's Avatar
not much at all. usually around 300.
Old 07-25-2011, 04:28 AM
RamAir95TA's Avatar
Stock cam orrrrrrr....?
A very small handful of bolt-on cars have reached 320+whp, but that is not the norm, 280-300 being common.
Cam-only cars have seen as much as 370whp, also not the norm, depending on the cam 310-350whp being common.
Old 07-26-2011, 03:43 PM
i E i's Avatar
I would say with cam....
Old 07-26-2011, 04:32 PM
Camaroking1996's Avatar
What kind of cam?
Old 07-26-2011, 09:15 PM
i E i's Avatar
Originally Posted by Camaroking1996
What kind of cam?
to be honest I know just about nothing about cams... and, is there a list of mods that you should do from the first mod to the second and so on...?
Old 07-26-2011, 09:24 PM
96capricemgr's Avatar
Sounds like you are asking how much power without taking the engine in for a performance rebuild?
If so ported heads and a cam can be put in a stock shortblock and with proper boltons over 420rwhp is possible.
HP comes from airflow, airflow is what the heads and cam do, they have a much greater impact on performance than rebuilding the bottom of the engine. More than anything the bottom half just has to be reliable at the rpm the heads and cam need to move air. That is a little oversimplified but is a response to the popular missconception that to add power you bore and stroke the engine. That can help but doing JUST that wont gain much.
