Edelbrock Torque Arm
LS1Tech Premium Sponsor
In my opinion they are not nearly as well built as our BMR torque arm and this is for a couple of reasons. The rear mounting bracket they use where the torque arm bolts to the rear end is considerably weaker than the one we produce due to the size plate they use to build it and lack of bracing. I know with the older Edelbrock torque arms they used a smaller tube diameter to build their torque than we do, I know we us 1.25" diameter tubing so you may want to measure the tubing. Also they use the stock style formed metal end that slides into the bushing, this is not nearly as good of a design as using the tubular style front on the torque arm. Using the tubular style front spreads out the load were as the the formed metal front piece that the Edelbrock torque arm uses puts a lot of pressure in one small area due to the design. I have had more than a few customers bend and break their Edelbrock torque arm so I would definitely see what your other options are becasue there are much better designed and performing torque arms out there like the BMR one we build. I hope this helps out a bit.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Man I am suprised your stock torque arm has held up to those sixty foot times, I have a handful of bent ones here at the shop.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Yes there is a couple guys I know still running the stock torque arm running those 60 foots amazingly enough. An aftermarket BMR or UMI would not flex like the stock one would though under launch. I believe the plate on the back brace of the UMI and BMR are thicker than the Edelbrock.
I have even had some auto guys bend the factory torque arm but you are absolutely correct with the T56 guys having more issue with the stock suspension.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
If you are interetsed in one of our BMR torque arms give me a call here at the shop and I will see what I can do on pricing for you.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
