Fuel for a 150 shot?
Help me out with mostly the fuel side of things...
late year 2003 Z06 with wet plate kit... and have been running a 100shot for a year or so. I have a LNC002... but what am i going to need for the fuel, or will stock fuel work?
the system. late 03 vettes have a different pump from the ones before.. and im not totally sure if i can run 150 wet...feeding fuel from the rail. pump upgrade options are pretty limited. Ive not really seen this question asked in the past i guess... (though im sure it has been).
basically... Late 03 Z06 with plate kit at 150 and LNC002 for timing... is this "safe"?
Guest
Posts: n/a
I would go ahead and either do the hotwire/255 combo or a BAP.
i don't mean to hijack but whats the info n specs of a stock 03-04 z06 fuel pump..being if their the same fuel pump..i'm pretty much in the same boat with BPG with deciding on spraying an occasional 150 shot.im starting with a 100shot
Guest
Posts: n/a
You are in the same boat. Same as above.
