The Oil Leak Mystery
Old 07-26-2011, 10:36 AM
TransAmFan88's Avatar
Default The Oil Leak Mystery
So I'm trying to figure out this oil leak, I don't think its the o-ring from the water pump because when i replaced the pump I made sure to put back in the right away as well as putting the bands on. What else could it be? got some pics, I just haven't had a chance to dig in the engine to look.
Any suggestions where I start? where are the most common leaks?
I have a 97 Trans am
Old 07-26-2011, 10:41 AM
RamAir95TA's Avatar
Could be one of the following -
Front main seal.
CPS sensor seal.
Opti seal.
Waterpump seal.
Valve cover(s).
Take your pick. That's a sizable leak. Definitely start taking stuff apart.
Old 07-26-2011, 11:20 AM
jasonisdn's Avatar
wipe it all down, then crank it and see if it leaks enough to spot it. also don't forget the front of the intake, as a source. they also make dye kits with uv lights that could help locate it.
Old 07-26-2011, 11:42 AM
draggin97s10's Avatar
id say front main and the crank is throwing it around but it could aslo be the above listed, wash/wipe it down and start ripping stuff apart
Quick Reply: The Oil Leak Mystery
