car will only start on second try
2000 camaro, Z28. When It is cold the car will crank good but not hit a lick. Stop cranking and hit the key again and it will fire right up. After it has warmed up it will start. Any suggestions?
Next time you start it cold turn the key to the on position but don't start it. Listen for the fuel pump to prime and then turn off, then start it and see if you have the same problem
