Running a racetronix below 1/4 tank
Old 07-27-2011, 01:08 PM
joblo1978's Avatar
Default Running a racetronix below 1/4 tank
Is this a no no? I've heard that running a performance pump below 1/4 can cause the pump to overheat and become damaged. Is this true?
Old 07-27-2011, 09:20 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
The Racetronix will perform exactly as stock, so you are ok under 1/4 tank.
Common practice is to refill at 1/4 tank regardless of the pump style.
Old 07-27-2011, 10:27 PM
chevymec's Avatar
Ive done it plenty of times, yet I know its not good for it over time.
Old 07-28-2011, 10:46 PM
sjsingle1's Avatar
as long as the pump works..........the bucket is full.......and the pump is cool
Old 07-29-2011, 11:38 AM
LS1TECH Sponsor
You can drive the car until empty, but I do not recommend racing or hard acceleration when the fuel level is low. Under hard acceleration, the fuel can be drawn away from the bucket. The pump then relies on the reserve of fuel in the bucket to feed the car. If you have a high HP motor this is only a few seconds worth of fuel. The bucket works fine on a stock vehicle, but if you have big power, you will quickly use the small volume of fuel in the bucket...
