F-body T56 Bellhousing, valve covers, and lots of other random parts
Category: Drivetrain
Price: $1234
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, 04-06 Pontiac GTO, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): AZ
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Stock Truck Belt Tensioner without Idler Pulley. The pully shown is not correct for this item and is not included. Less than 3000 miles on the tensioner. $10.00
2008 LY6 stock valve springs. Includes springs, retainers, locks and valve seals/spring seats. Less than 3000 miles on these. Replace your high mileage stock springs with these as preventive maintenance. $20.00
2008 LY6 stock pushrods. Less than 3000 miles on these. $10.00
Brand new Edelbrock LS header gaskets. These came with my Edelbrock LS swap headers and I didn't use them. $10.00
Two Brand new N20/Line Lock/Trans Brake shifter-mount switches. One is Hurst brand and the other is Summit brand. The switches are identical except for the wire type. Both came with line locks kits I bought for my cars and I used other buttons. These are the "doorbell" style switches with a rubber strap for shifter attachment. These sell for $22.95 each at Summit. $10.00 each
Brand new 3.5in "U bolt" Exhaust Clamps. I have two of these. They came with my Torque Tech exhaust system and I didn't use them. $2.00 each or $3.50 for the pair
Brand new 3 in "U bolt" Exhaust Clamps. I have 10 of these. They came with my Torque Tech exhaust system and I didn't use them. $2.00 ea or $15.00 for all 10.
Brand new Universal Exhaust Hangers I have four of these (two different styles). They came with my Torque Tech exhaust system and I didn't use them. $3.00 ea or $10.00 for all four.
Lightly used Chrome 12-bolt cover. Came on the Moser 12-bolt in my 99 TA and I replaced it after a few months with an aluminum stud girdle. Will fit any car 12-bolt. Disregard the radiator in the pic unless you happen to need a cheap 3-row radiator for a 2nd Gen F-body…LOL.$10.00 for the cover
Brand new Summit Black -8AN Female to ½ tube adapter fittings. I have two of these left over from my fuel system install. $4.00 ea (sells for $7.95ea at Summit).
Moroso Spark Plug Indexing Washers. For 14mm Tapered seat plugs (LS motors). I opened the pack and used only one washer. $5.00 for the pack. (sells new for $15.95 at Summit)
Brand new Taylor Negative Battery Cable. 20 inch long, 1-gauge welding cable. Top Post style. Came in my Taylor battery relocation kit and I didn't use it. Pictured bottom left$10.00
Please disregard the other three items in this picture (CE mounts, weather strip, older battery cable). They are either sold or are 2nd Gen F-body specific.
First up is an LS1 F-body T56 Bellhousing. This came on my replacement D&D built T56. I ran this bell for probably less than 500 miles before swapping it for a Quicktime bell. SOLD
Two Driver's Side LS Valve Covers. The one pictured on top is off of a 2008 LY6 with less than 3000 miles. Includes bolts and bolt seals. SOLD
The one pictured on the bottom is off an unknown milage 4.8 or 5.3. Great shape...just needs cleaned up. Includes bolts and bolt seals. SOLD
Brand new 3 inch 3-bolt header collector flanges with gaskets and hardware. They came with my Torque Tech exhaust system and I didn't use them. SOLD
