Slight hesitation?
Slight hesitation?
I have a 2000 z28 a4 which is pretty much stock, and i have this slight hesitation right around 2500-2800 rpm on acceleration and i have not a clue what it is, i definately notice it in second gear when i'm about half throttle and up, its not really a bog just a hesitation that last about half a second or so..
Thanks for the help
Thanks for the help
I had this problem once & it turned out to be a dirty MAF sensor.
LOL, one of the joys of owning a K&N air filter.
Take some electronical cleaner & Q-tips & clean it really well.
Make sure the small wires are clean & free of oil.
Just be careful not to break them.
Yeah, K&N air filters have a tendency to get oil on the MAF sensor.
I had a very similar hesitation at around 2500 rpm.
Get a can of CRC electronic cleaner. It comes in a red & white spray can.
Soak the MAF sensor thoroughly & clean the wires off with Q-tips.
It worked like a charm for me.
Good luck man.
Good luck man.
Just so people know.......be careful touching the tiny little wires with a q-tip.......it can break the wire and then you'll be buying a new MAF. If you get a can of CRC MAF cleaner and just blast the spray directly into the MAF through the screen, real good, it will clean everything off that might be there.
Good luck man.
Good luck man.
hopefully the TS can get his to work
