pcv delete help
Old 07-27-2011, 07:01 PM
slowblackformula's Avatar
Default pcv delete help
hi i recently bought a 98 formula so im new to f bodies. i was reading up on the pcv delete, i know to vent the fill cap but i am confused on what to cap off besides throttle body. if anyone has better pictures what to cap off and remove that would help me greatly. also what do i do with the driver side rear pcv ? thanks again
Old 07-27-2011, 07:36 PM
bayer-z28's Avatar
^ You don't delete the PCV. You'll just end up with leaking gaskets and lowered power. You can upgrade it so you won't ingest as much. These in stock form are notorious for drinking ~1qt of oil between changes, depending on your driving style.
You can run a breather on the filler cap, but that's been debated quite a bit. You can upgrade to a single or dual catch-can setup to catch oil before it's sucked into the intake... or you can upgrade to the LS6 valley AND a catch can to grab every ounce possible.
Old 07-27-2011, 09:02 PM
LS1121's Avatar
Or you can do what I did on my 98 Z28.
Old 07-27-2011, 09:42 PM
mean_greenZ's Avatar
^^^ which is what??
Old 07-28-2011, 12:40 AM
LS1121's Avatar
repair it.
Old 07-28-2011, 12:49 PM
so i just want to leave it all on there ?
Old 07-28-2011, 02:09 PM
The Scammer Hammer
dr_whigham's Avatar
For 12 bucks, you can do what LS1121 did. I personally think it's a band-aid to a gunshot wound, but what he did wasn't half assed. It's about as good as a stock replacement is going to get.
Still, when money permits, introduce yourself and make friends with:
GM Part # 12577927 - LS6 Valley cover, comes with bolts & gasket
GM Part # 12594779 - Hose
Old 07-28-2011, 05:21 PM
LS1121's Avatar
What he said.
Old 07-28-2011, 10:56 PM
I read something on a newer designed Pcv valve suppose to help with the burning oil can I just replace my stock with that and leave all the hoses and stuff stock. Sorry for all the questions im just confused working on this car
