Water pump install help, what is this O ring
My friend camaro z28 97 water pump is leaking, I brough new GMB Water Pump Part No 130-7100 from advance auto part. I have few question
Their is 1 little O ring that came with 2 gasket on the water pump kit, where that O ring go ?
about the coupling on driveshaft , I saw a pix on shbox and it have 2 O ring, but mine do not have O ring.
some peoples lube the coupling tube , what I need to use ? do I need it ?
I take off the coupling on driveshaft to clean, does it matter which way it go back in, cause I dint pay attention, I note one side have a circle mark around it, is that side with circle mark , its for the engine side or water pump side ?
where the black o-ring in the post above is, my 95 coupling has some sort of plastic o-ring, or washer, its on there pretty good, and not sure if i even need to replace it with new o-ring? any thoughts
I know this is older but I have a question about the water pump drive gear. Is it suppose to have that grove in there like that? I thought I saw some that were all flat with out the grove. ( talking about the grove ring on the silver piece in that picture )
The seal surface area is completely flat and smooth on a new drive. Any groove is caused by wear from the seal. I think that picture show more of a shiny area that might look like a groove, but perhaps there is a little wear.
Ok thanks, as my motor sits now and the drive gear is out mine does have a grove, and i was trying to figure out if i need to geta new one. I'm guessing I will have to pick one up then since we figured the grove was worn in. ( the rubber gasket was hard )
