Installing Hella Fogs, how to use stk switch instead
Old 07-28-2011, 09:18 AM
mrrman's Avatar
Default Installing Hella Fogs, how to use stk switch instead
I have installed Hella Fogs in my car and they came with the Bosch relay and on/off switch with 3 contacts. I want to use a stk Trans Am switch which I pulled off a wrecked car. How do I wire this switch up and use it just as an on/off. I assume I need one blade to be a ground and the other to be power. Ay help appreciated.
Thanks
Old 07-28-2011, 05:24 PM
2000TransAmWS6's Avatar
i think you're right, you would just need a power and a ground. on the 3 term switch, one of the terminals is for a light in the switch.
i'd like to see what those Hella fogs look like installed. you able to post a pic?
Old 07-28-2011, 10:03 PM
mrrman's Avatar
Ill take one later and post it...I just have the stk ones in a pic that I removed
Quick Reply: Installing Hella Fogs, how to use stk switch instead
