Which 02 sensors to buy?
Denso...2344025 16 inch wire with plug end. It will work in any of the 4 02 sensor positions, the sensors are all identical, its the length of the wires that changes the part numbers. Just get the long wires and zip tie the extra length to the frame.
www.rockauto.com
or
Amazon.com
About $33.00 each.
DO NOT buy Bosch crap sensors. Densos are the best sensors ever made. GM puts these sensors in their AC Delco boxes and sells them as GM sensors, have been for about 2 years now. But you will pay upwards of $180.00 each at the stealership......SAME exact sensor in the same Denso sealed bag.
www.rockauto.com
or
Amazon.com
About $33.00 each.
Some cars have no trouble with Bosch though....its hit or miss. Either way Bosch is complete crap compared to Denso. Mine arrived today via UPS......Ipaid for them yesterday on Amazon.....they arrived today. $75.00
If I'm ever in Lafayette again, which I am occasionally for work......I'll call ya...
the 2344025 are not the same as the 13111's. Those Densos are FACTORY replacements. I bougth those Denso's thinking they were right but got the headers on and those 16" ones are about a foot too short. So I had to go to two different parts stores and buy the 13111's . If I could have bought the denso's (Part# 2344617) i would have.
Doesn't matter though......its up to you to get the right wire length........thats why the part numbers are different. Just order the proper Denso.
Amazon.com has Part #2344617 Densos too, right now in stock. $53.00....44 inch long wire.
NEWS FLASH.......BUT THAT PART NUMBER.......DOES NOT FIT OUR F-BODY's......
I've been using the 2344087's for years. The fit my 1 7/8 LT's just fine. But I bought the 2344025's this time because of 4 more inches of length, because I'm going to heat wrap all of my 02 sensor wiring this time and wanted extra length.
My rear 02's have been tuned out since 2002 when my 427ci went in.
If Amazon is out.....these are $34.00...free expedited shipping.
http://cgi.ebay.com/ebaymotors/Denso...#ht_2118wt_732
The Scammer Hammer
Not so lazy after all....
13111 has a 50" wire? Is that about right?
If so, Denso Part #2344617 should be for long tube headers, right? Or will they be a few inches too short?
Point is I do NOT want to use extensions. LS6427, how did you get them to work, when 85camaroZ28 says they are too short?
**edit** just saw another thread where a guy says the 13111's are about 30"... Aggrevation is setting in
2344617 WILL NOT work for 98-02 F-Bodys. It will only work on Corvette 1997-2003....Corvette Z06 2001-2003
If you buy 2344025 it will work in any position.........PLENTY of wire. You will be zip-tying extra wire to the frame.
The Scammer Hammer
Let's throw a wrench in things.... The concensus is that the 13111 is the one to get so as to NOT have to run o2 extensions.
I went to autozone online, and said my car was an 04 ZO6. You should see all the options for after-cat o2 sensors.
http://www.autozone.com/autozone/par.../N-jler5Z9ixrp
WTF?
They list Bosch 13111, 13450, & 13483 all as downstream O2's
Denso lists 234-4209 & 234-4104, both as downstream O2's
Why all the different part #'s?
OP, sorry for the Don't really want to start a new thread and I figured it would help us both out.
WTF?
Alright "dr_whigham",
My 02 sensors were delivered today. I went outside, put my car on ramps and installed them. I bought Densos from Bennett Auto last time. Looks like the drivers side wire was about 10 inches long....and the passengers side wire was 14" inches long. I have no idea what the part numbers were back then, they just gave me an upstream right and an upstream left....which is all I need with LT's and my rear 02's tuned out.
Look at the pic below, there's the two I just took out. The new 2344025 (16" long) fits but there's not much extra, but I also shoved the wire behind and to the top of the heat shield, so that took a little more than that old 10" wire. The passenger side new 2344025 (16" long) has a little extra wire that I zip-tied to my tranny lines like last time.
So the 2344025 Densos are 16 inches long.....I don't see how they won't work on anyones F-Body with LT's......
Those 13111's....I have no idea what I would do with 30" of wire....lol
BUT......Maybe there's some LT's out there that are way different than mine.......so simply get under the car for 30 seconds and measure for what you need. Be sure.......
www.rockauto.com
or
Amazon.com
About $33.00 each.
www.rockauto.com
or
Amazon.com
About $33.00 each.
Anyone know if these will work for an 04 5.3L? I swapped it into an 01 Mustang and replaced the factory ones with the Bosch ones and it won't run with them plugged in.
What year PCM are you using? I think that would determine it. If its a 98-02, I don't see why not.
Denso 2344025 and 2344087 fit all these cars. SAME exact sensor, they are listed to for there specific cars because of the wire lengths and the different positions. Just measure.
2344087 is listed to fit these:
BUICK CENTURY 2003
BUICK CENTURY CUSTOM (1996 - 2004)
BUICK CENTURY LIMITED (1997 - 2004)
BUICK CENTURY SPECIAL 1996
BUICK LESABRE 1999
BUICK LESABRE CUSTOM (1996 - 2003)
BUICK LESABRE LIMITED (1996 - 2003)
BUICK PARK AVENUE (1996 - 2003)
BUICK PARK AVENUE ULTRA (1996 - 2003)
BUICK REGAL (1999 - 2000)
BUICK REGAL CUSTOM 1996
BUICK REGAL GRAN SPORT 1996
BUICK REGAL GS (1997 - 2003)
BUICK REGAL LIMITED 1996
BUICK REGAL LS (1997 - 2003)
BUICK RENDEZVOUS (2002 - 2004)
BUICK RIVIERA (1996 - 1999)
CHEVROLET CAMARO (1996 - 2002)
CHEVROLET CAMARO RS (1996 - 1997)
CHEVROLET CAMARO SS (1998 - 2002)
CHEVROLET CAMARO Z28 (1996 - 2002)
CHEVROLET IMPALA (2000 - 2004)
CHEVROLET IMPALA LS (2000 - 2003)
CHEVROLET LUMINA (1996 - 2001)
CHEVROLET LUMINA APV 1996
CHEVROLET LUMINA LS (1996 - 1997)
CHEVROLET LUMINA LTZ (1997 - 1998)
CHEVROLET MONTE CARLO 1999
CHEVROLET MONTE CARLO LS (1996 - 2004)
CHEVROLET MONTE CARLO SS (2000 - 2003)
CHEVROLET MONTE CARLO Z34 (1996 - 1998)
CHEVROLET S10 PICKUP (1997 - 2003)
CHEVROLET VENTURE (1997 - 2004)
GMC SONOMA (1997 - 2003)
ISUZU HOMBRE (1997 - 2000)
OLDSMOBILE 88 1999
OLDSMOBILE 88 ROYALE (1996 - 1998)
OLDSMOBILE 88 ROYALE LS (1996 - 1998)
OLDSMOBILE 98 REGENCY ELITE 1996
OLDSMOBILE AURORA (1996 - 1999)
OLDSMOBILE CUTLASS CIERA SL 1996
OLDSMOBILE CUTLASS SUPREME 1997
OLDSMOBILE CUTLASS SUPREME SL (1996 - 1997)
OLDSMOBILE INTRIGUE (1998 - 1999)
OLDSMOBILE LSS (1996 - 1999)
OLDSMOBILE REGENCY (1997 - 1998)
OLDSMOBILE SILHOUETTE (1996 - 2004)
PONTIAC AZTEK (2001 - 2004)
PONTIAC AZTEK GT 2001
PONTIAC AZTEK RALLY 2004
PONTIAC BONNEVILLE (1999 - 2003)
PONTIAC BONNEVILLE SE (1996 - 1998)
PONTIAC BONNEVILLE SSE (1996 - 1998)
PONTIAC BONNEVILLE SSEI (1996 - 1999)
PONTIAC FIREBIRD (1996 - 2002)
PONTIAC FIREBIRD FIREHAWK 1998
PONTIAC FIREBIRD FORMULA (1996 - 2002)
PONTIAC FIREBIRD TRANS AM (1996 - 2002)
PONTIAC GRAND PRIX (1996 - 2002)
PONTIAC GRAND PRIX GT (1996 - 2003)
PONTIAC GRAND PRIX GTP (1996 - 2003)
PONTIAC GRAND PRIX SE (1997 - 2003)
PONTIAC MONTANA (1999 - 2004)
PONTIAC TRANS SPORT (1996 - 1999)
PONTIAC TRANS SPORT MONTANA 1998
2344025....is listed to fit these:
CADILLAC DEVILLE (1996 - 1999)
CADILLAC DEVILLE CONCOURS (1996 - 1999)
CADILLAC DEVILLE DELEGANCE 1997
CADILLAC ELDORADO (1996 - 1999)
CADILLAC ELDORADO ETC 1998
CADILLAC ELDORADO TOURING (1996 - 1997)
CADILLAC SEVILLE 1999
CADILLAC SEVILLE SLS (1996 - 1998)
CADILLAC SEVILLE STS (1996 - 1998)
CHEVROLET CAMARO Z28 (1998 - 2002)
PONTIAC FIREBIRD FORMULA (1998 - 2002)
PONTIAC FIREBIRD TRANS AM (1998 - 2002)
I and just about everybody I know runs the 13111 and none of use had any problems. Perhaps you got a bad sensor but instead of finding a working replacement you decide to bash Bosch for the rest of your life. That's childish and irresponsible IMO.
I'm just really confused now. Can anyone clear this up for me? so I buy bosch 13111's I'll have a crap load of wire to zip tie right? And if I buy these denso's which are supposedly super awesome for less which part number do I order for my FBODY ta with LT headers? I dont recall if it was ever made clear whether he ran these with his Fbody or a corvette. I need to order some o2 sensors ASAP so the sooner the better
I put Bosch in my car and they work great!! It's like everything else here, a person asks a question there are many answers but some people I guess just always want to be right. I've been bashed a lot lately for my opinions. I try to help, if you don't like what I'm saying then just spend your money the way you want.
See, some PCM's will not except Bosch................ All PCM's are NOT the same in our F-Bodys. Some do their own thing.
BUICK CENTURY 2003
BUICK LESABRE 1999
OLDSMOBILE 88 1999
BUICK CENTURY 2003
BUICK LESABRE 1999
OLDSMOBILE 88 1999
