Got a question on tranny
Yes it will bolt up to the engine, it will only use 5 bolts though,,, there are a ton of guys out there making crazy power and running 400s so dont worry about the 5 bolts. I do believe you are going to have to get a new driveshaft,, I also think that most of the guys run a short tail trans in these cars, so you may have an issue with the crossmember not sure.
