Need sum help
Old 07-28-2011, 11:07 PM
bBody22's Avatar
Default Need sum help
i am having a firing issue with my 1994 caprice Lt1. I put a new opti spark on it and it ran just fine for about 2 months then it wouldn't start ( wasn't firing). so i exchanged for a new opti-spark and it will not fire. so i was wondering is there anything else that will make me have a firing issue?
P.S. i also tired another ICM and put another knock sensor on it. Help is needed quick
Old 07-29-2011, 09:21 AM
Dave357LT1's Avatar
You check the coil and fuel pressure? VATS?
Old 07-29-2011, 10:04 AM
bBody22's Avatar
its a new MSD coil and i just bought a new fuel pump. what VATS?
Old 07-29-2011, 10:21 AM
Bullit95T/A's Avatar
(VATS)Security light come when it starts and go off after a few seconds?
or Does just stay on?
Old 07-29-2011, 10:40 AM
djjab57's Avatar
Have you checked your fuel pressure ?
Old 07-29-2011, 10:58 AM
Dave357LT1's Avatar
Msd's have been known to fail and just because its a new pump dosnt mean its working.
Old 07-29-2011, 01:32 PM
bBody22's Avatar
No i don't have anything to check it with, and plus it will not start any how
Old 07-29-2011, 01:33 PM
bBody22's Avatar
yes when i got the first opti spark on it and it would start and die after about 20 mins. so i check the fuel psi and it was at around 42 and stayed there the whole time. so i change the knock sensor and it ran just fine.
Old 07-29-2011, 01:35 PM
bBody22's Avatar
the pump went out one day while i was driving, i put another one in it and its been running fine and i can also hear it when it first comes on.
Old 07-29-2011, 07:37 PM
defaultexistence's Avatar
Check and repair the 12v terminal on the passenger fender firewall near fuse box, I had one with a bad connection cause a no start condition..
Old 07-29-2011, 09:32 PM
nomoneyz's Avatar
What kind of optisparks are you buying. GM ones I hope.
Quick Reply: Need sum help
