BMR boxed or Spoohn Tublar LCA's
Old 03-02-2004, 12:06 PM
HumpinSS's Avatar
Default BMR boxed or Spoohn Tublar LCA's
Car is used for drag racing. TIA
Old 03-02-2004, 12:21 PM
9 Second Club NA
Dragaholic's Avatar
I personally like my chromoly tubular Spohn LCAs w/poly/rod combo. All his pieces are nice. If its a race only car, then get the rod ends on both ends. But if you plan to do a little driving on the street, get the combo as i did. Good luck with your choice.
Old 03-02-2004, 12:25 PM
HumpinSS's Avatar
Which side is the rod end installed on
Old 03-02-2004, 12:32 PM
9 Second Club NA
Dragaholic's Avatar
Rod end on rear, poly on body. The poly is to dampen the noise and the rod is to allow the rear to move correctly without binding.
Old 03-02-2004, 07:20 PM
Revelation222's Avatar
My dual rod CM Sphon's will be here this week I believe. I'll let you know how they work out.
