LS4 Performance - ideal transmission fluid temp
xxtheshockerxx
07-31-2011, 02:28 PM
I recently got the App Torque on my phone. I have been monitoring my trans temp today.
It seems to stay around 200-210....it is about 94F today
is that an alright temp? i know i want to do the tranny cooler soon. What kind of temps might i see with a cooler?
thanks guys
rvd9431
07-31-2011, 05:53 PM
it was 95 today, after about 1 hour driving, including sitting 5 mins in MCD's drive thru, a/c on, it got to 186, highest Ive ever seen my trans get was 191
I have a 6 pass flexalite cooler from JEGS
xxtheshockerxx
07-31-2011, 06:07 PM
http://www.jegs.com/i/Flex-a-lite/400/3820/10002/-1?parentProductId=756324
is that what you got? easy install?
vroom_vroom
07-31-2011, 06:12 PM
175 is the ideal for out trans
xxtheshockerxx
07-31-2011, 06:35 PM
i am a little high then. i better get a cooler on it soon
vroom_vroom
07-31-2011, 08:13 PM
yea without it i would see 210 on the regular she stays at 188 in the 110 degree weather unless i am riding the gears. but i have not seen 200+ even beating on it with my cooler but i have a new converter as well
xxtheshockerxx
07-31-2011, 09:00 PM
thanks guys. i think i will have to buy a cooler very soon. i would like to keep it as cool as possible with all the problems these trannys have
DavidGXP
07-31-2011, 09:18 PM
No higher then 200* 185* is Ideal
xxtheshockerxx
07-31-2011, 10:46 PM
thanks:nod:
redeemedtat2
08-01-2011, 05:26 AM
thanks guys
App Torque? Apple or Android? Does this let you read your trans temp on your phone? I've seen the GXP guys making reference to their trans temps and knew they could read that on their DIC, but wondered how us Impala owners were supposed to monitor it?
wesdean78
08-01-2011, 06:23 AM
I know there's a Droid version; I don't know if there's an Apple version.
http://torque-bhp.com/
and
http://torque-bhp.com/wiki/Main_Page
Wes
xxtheshockerxx
08-01-2011, 10:44 AM
i use it on droid. it works pretty damn good for a $4 app
redeemedtat2
08-01-2011, 11:44 AM
okay i installed the app, cool gismo, but i don't see the transmission temperature option?
and do you have to go bluetooth with it? i have this adaptor from vince at trifecta but it's usb.
xxtheshockerxx
08-01-2011, 02:56 PM
i got a bluetooth OBDII sensor to plug in. it cost me around $20 on ebay.
make sure you load the GM PIDs in the settings.
if you have any other questions ask cus sometimes the app likes to be difficult to set up the first time
xxtheshockerxx
08-01-2011, 04:38 PM
Can anyone else give me a suggestion on which trans cooler to get? I dont know alot about them and want to get the best one i can for the application
rvd9431
08-01-2011, 04:48 PM
few hours install in my garage
http://s242.photobucket.com/albums/ff210/BlueStreak_95/trannycooler/
Used that as a guide, I also used the air hose splicers he used in that how-to, also double clamped only the cooler side, not the spliced side as the clamps i got wouldnt clamp properly with two on the splicer. The mounting location will have to be different, I put mine in front of the condenser resting on the lower plastic cover.
This is the cooler I bought, but the one you posted would work too, its bigger and will probably cool slightly better
http://www.jegs.com/i/Flex-a-lite/400/3818/10002/-1?parentProductId=756324
xxtheshockerxx
08-01-2011, 04:58 PM
thanks for the quick response. I will really look into the Flex-a-lite coolers. They seem pretty popular in this forum
vroom_vroom
08-01-2011, 06:26 PM
just depends how much you wanna spend, earls performance makes one that is as big as your a/c condenser.................... the b&ms are my personal fav, went with a derale on mine due to i was leaving for a trip and wanted it before hand
xxtheshockerxx
08-01-2011, 06:35 PM
seems like 40-60 bucks will get a decent one. but i wouldnt be opposed to spending a little more really
B&M seems to make a good one too.
redeemedtat2
08-01-2011, 06:41 PM
thanks shocker.
xxtheshockerxx
08-01-2011, 08:20 PM
thanks shocker.
no problem
Low91
08-01-2011, 09:59 PM
Instead of cutting up the factory line I found some barb fittings from derale (PN D13035) that fit into the radiator and transmission just like the factory line. That return line is a PITA to get to and splice on the MCSS so Ijust removed it all together. I never liked mounting coolers directly to the condenser so I used some 4" corner braces to put it behind the bumper.
http://i214.photobucket.com/albums/cc181/justin82285/07032011004.jpg
http://i214.photobucket.com/albums/cc181/justin82285/07032011001.jpg
xxtheshockerxx
08-01-2011, 11:18 PM
^^^ that is the hi-fi cooler. you know what temps you run with that?
thanks for the info
Low91
08-02-2011, 09:08 PM
I'm not sure of the temps, I've got no way of reading it. The fan kicks on at 180, off at 170. I wired it to run even with the key off( to lazy to find a "key on" wire) and it only continues to run during the 100*+ days. So I'd guess between 180-190*
steveman0018
09-20-2011, 04:48 PM
I know this thread dates back a month but i just got the torque app with the OBDLink bluetooth interface and i cant get the tranny fuild temps to work.. It shows on my gauge selection Tranny Fuild Temp Method 1 and 2 but it only reads 32 degrees F. What am I doing wrong shocker?
xxtheshockerxx
09-20-2011, 04:50 PM
did you load the GM PIDs?
steveman0018
09-20-2011, 04:54 PM
how do you load them? I can see them in my gauge selection and it says the raw data is 32 degrees F but never moves
07MCSS
09-20-2011, 05:08 PM
I bought a Torq Flo p/n 911516 from Autozone. I got it for $59. I got 3/8 barbed fittings from Home Depot for $5. My temps have never gone above 180* since I installed it.
