Small Block & Big Block Chevy Specific - sbc bellhousing pattern 305 - 307 - 350
1 FMF
07-31-2011, 04:51 PM
have a '76 boat that has 220 hp chevy's in it, built/assembled by crusader marine. The motors are either 305 or 307 chevy blocks. One is reverse rotation. The powertrain setup is the motor, bolted to a transmission, bolted to a walther v-drive, all 1976'ish era. If i should ever decided to mess with it or it's sold, will a late model chevy vortec 350 bolt right up with the transmission and bellhousing? Is the bolt pattern the same?
sideways87
07-31-2011, 07:24 PM
Yes , all the sb chevy's use the same pattern up to the lsx engines.
87silverbullet
08-01-2011, 08:33 AM
Even the LS engines bolt up to the old SBC transmissions just one less bolt goes in.
cambirdracing
08-01-2011, 12:14 PM
And big blocks and 90 degree v-6's and straight 6's.
