What is an "oil filter adapter" when talking about gauges?
I'm about to order this kit:
http://www.glowshiftdirect.com/93-02...e-package.aspx
The gauges I'm getting are:
Trans Temp Gauge
Air / Fuel Ratio Gauge
Oil Temp Gauge
It asks if I want an oil filter adapter, and idk what it would be used for. It also asks if I want the three gauge wiring kit, which I'm assuming I need.
Trans Temp Gauge
Oil Temp Gauge
The oil filter adapter is the part between the oil filter and the engine block, its the actual part where you mount/bolt your oil filter. There's some that you buy to replace the stock unit with provisions for an external oil cooler.
