my 67 camaro lbs
my 67 camaro lbs
well i took it in today to the scale finally after 3 years ive been wanting to weigh it in and it came out to 3075 lbs, im pretty happy with that
well i knew that the new front clip i bought was said to be at 150 lbs lighter then the stock front suspension clip so that helped and then the ls1 aluminum engine is a lot lighter then the stock cast iron 327 it had on before, the only thing that made the car really heavy was the 9'' rear end i put in there, the stock 10 bolt was a lot lighter then the 9 inch but im sure it would not have held the power the ls1 is putting out
