One sick WS6 Triple Blk Vert w/ mods
Year: 2002
Make: Pontiac
Model: Trans Am
Price: $19000
Mileage: 65000
Private or Dealer Listing: Private Listing
Location (State): MN
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
I believe 1 of 74 triple black 6-speed convertibles in the last production year of 02.
65,000 miles great paint and interior No rock chips!
Mustang Dynamometer test report provided from a Custom dynotune by Straightline Performance (1320hp.com) currently producing 470 rwhp and
526 rwtq on pump gas on a conservative tune at 13 degrees of timing.
Extra set 317 heads (6.0) This will lower compression by a point so you could run 12-14 lbs of boost and make some serious #'s
The turbo spool and blowoff valve sound is amazing. Gobs power and torque at all Rpms.
Have 15k in aftermarket parts.
Built stage 2+ T-56 by The Gear Box with Timken bearings good to 700hp+
Autometer guages: Digital Air/Fuel ratio, Boost psi, & Fuel Pressure
Upgraded Garrett 67mm BB Turbo with oil pump failure alarm
Methanol Injection system with knock sensor warning alarm
Electronic boost controller w/ in dash switches (Set for 5psi low and 8psi high)
New Monster stage 3 clutch good to 750hp!
60 lb injectors
255 LPH Walbro fuel pump
Tick master cylinder
6pt bolt in wolfe roll cage w/ swing outs (easily removable)
HP Tuners Pro
SLP Line Lock
email raiderchad@live.com for more info or additional photos
