Question about AC compressors, having some issues
Old 08-02-2011, 03:39 PM
Formula413's Avatar
Default Question about AC compressors, having some issues
I'm replacing the AC compressor on my car and I'm running into a problem. I've put two different compressors on there, brand new (not reman), different brands, and they both have the same problem. As soon as I start it up the pulley starts squeaking. It sometimes quiets down a little as I drive but the next time I drive the car it comes right back. I can put the stock one back on (replacing it due to it leaking) and no noise at all. I can't believe two different brand new compressors could have the same problem. Is it normal for this to happen? The only thing I could think was that maybe the noise would go away after a few engage/disengage cycles of the clutch, does that make any sense? Just want to make sure I'm not missing anything before I R&R the compressor for the THIRD time...
Old 08-02-2011, 03:51 PM
5.7mmImportkilla's Avatar
It might be a good chance is the belt.. Have you replaced it too?
Old 08-02-2011, 03:54 PM
Formula413's Avatar
Serpentine belt is brand new, and again no noise with stock compressor.
Old 08-02-2011, 09:54 PM
1 FMF's Avatar
did you put oil in the new compressor before installing it?
Old 08-02-2011, 10:25 PM
Formula413's Avatar
Yup. Compressor has not even been run yet, it's the pulley making the noise.
Old 08-02-2011, 10:37 PM
wrencher
wrencher's Avatar
Is there alignment dowels on the new compressor to mount it properly to the bracket?
Old 08-02-2011, 10:46 PM
Formula413's Avatar
I didn't see anything like that, the mounting ears sit right against the accessory bracket.
