P1sc-1
P1sc-1
I wanna know how much power can I pull out of a P1SC-1 with out cutting my pistions and blowing my bottom end, a friend of mine said it made 560wrhp
ad 494ftlbs with heads/cam 60lb injectors and a meth kit, and other mods on a sotck bottom end, can a p1 put out yhode kind of numbers?
If you throw some 317 heads on there you can lower the compression a bit and make your stock bottom end a bit more boost friendly. A boost friendly cam will also do wonders for a stock LS1 under pressure.
I make 470ish on a mustang dyno at 6100rpms. stock 98 motor heads never been off. Ls6 intake, cam, and headers. Been there for ~4 years. Crane cams had a 98 pushing around 600hp dd... (had disc but...)
LS1Tech Sponsor
You'll be just fine with the twin intercoolers, especially since you have a methanol injection kit. You'll want to run 100% methanol, as a 50/50 mix tends to put out the flame with forced induction. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
