lowering with S60? torque arm for street car?
I recently purchased a higher milage 99 SS M6 and am going through the suspension and drive train components before I start adding power. I want to lower the car, but I have heard that it isn't a good idea to lower a car with an aftermarket rear due to clearance reasons. Is this true? I want to put a set of strano springs on the car with a set of bilsteins when I rebuild the front end/replace the rear end, so that I only have to have it aligned once.
I also plan to upgrade the torque arm as well. From what I have read, it is best to use a long torque arm with a relocation crossmember to move the torque arm off the trans. I know the tunnel mounted setups transmit a significant amount of vibration into the car, and since I drive this daily (80 miles/day), I do not want excessive vibration.
I have already added subframe connectors, double adjustable lower control arms with poly bushings, and an adjustable on car panhard bar with poly bushings, and I don't have any issues with vibration so far.
LS1Tech Premium Sponsor
Since you are going to daily drive the car you want to definitely stick to the full length adjkustable torque arm along with torque arm relocation crossmember. This will give you the best driveablility but will also help out the performance of the car, we have had guys run deep into the single digits 1/4 mile-wise using this setup.
If you are interested in pricing out som BMR parts shoot me a PM or give me a call here at the shop. I attached a few pics of our BMR full legnth adjustable torque arm and BMR torque relocation crossmember.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Here is a schematic and I can have them cut before it goes to powdercoating if you guys buy the torque arms directly through us.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
